Windows 7 build 7077
What do you mean doesnt need a serial??
Yes it does, if you mean to install, none of them did?? :confused:
But to activate and continue to use it past 30 days you need a serial
All previous Builds have required serials in the loading stage! This one has not and has taken down some updates
My Win7 7048 build (that was upgraded from 7000) is running fine, currently has a 33 day uptime! although the sidebar has been eating memory since boot, currently taking 243MB :)
I am trying to resist temptation to format and reinstall 7077 with RC1 so close around the corner!
Thanks for heads up. Am currently running 7048 (from 7000) and thought I'd wait for a few before upgrading again.
Don't know where you've gotten that from, I've used every build since 6801 up to 7068 and none of them have required a serial key during the instalation. :confused:
I've either used the serial after its installed and in windows, or not bothered because I had reinstalled windows again within 30 days.
ati catalysts wont install for me with 7077
9.4's wont as ATi ballsed them up, when you try to install them, only the CCC will install, so you have to go to the Device Manager and Update the Driver that way, by telling it to browse in :- 9.4 > Packages > Driver > Display > LH6A_INF :)
yup tried that, had to do it that way in the 68 build, they wont do it in 77 build 64 bit :-(
C:\Users\Yourname\AppData\Local\PunkBuster\WAW\pb >
PnkBstrA
PnkBstrB
Vista service pack 2 compatability mode
Thats with patch 1.4 and Windows 7 x64 7077
Anyway of running the Setup telling it to ignore any compatibility prompts?
Mine keeps harping on about some file I cannot find and the install wont continue?
