Actually yes it is a debate heh you have people who are too scared to even consider the possibility that it was anything but what the official statements say
Actually yes it is a debate heh you have people who are too scared to even consider the possibility that it was anything but what the official statements say, you have people who are deludedly swallowing every CT going and people who are somewhere inbetween but being painted as being in one corner or the other by the people in the 2 extremes.
And some people just posting for a laugh to stir things up.
Sure and meanwhile I'm still not seeing anything that moves me from my viewpoint that while the theory that has the most evidence backing it is the most plausible, it doesn't comprehensively deny the possibility of not entirely unreasonable alternative theories.
I think acid, may have a background in civil engineering or at least a physics based subject, due to the fact that he saying sense.
The idea that a building can be pre-weakened is ludicrous due to the average stress and strains that a building has to fight daily.
Also i believe what i see, i saw a building hit by a plane, a building not designed to with stand earthquakes let alone a plane hitting it so far up.
Also a pretty old built building that didn't use a floating structure support system like the newer style buildings.
The force of a solid aircraft can transfer into a building is immense coupled with the momentum force that was applied to the base of the structure. could easily buckle the main supports of the building.
Also the force of the impact was shown to have splintered the concrete on supports, which when introduced to a flash heating and extreme pressure change can easily strip the concrete of the steel.
this results in the compression capablities of the supports being superoirly reduced. which ended with the collaspse.
Unfortunately for you i have physics on my side and shes a cruel bitch...
It's a known fact that the buildings were destroyed by explosives & that the planes which appeared to hit the towers were in fact holograms
Proof of what your saying or shut up.
Yes, but physics could be wrong and the CT's could be right. You haven't considered that have you? No, because the truth scares you![]()
do you want me to explain the physic behind how they collapsed or do you want to troll?
And I will ask you again which report do you back?
I know you have read them or you would not post here
or are you just trying to get your post count up.
go find another playground to play in![]()
I have not read any report but jet fuel burns off really quick with big flames and stuff (especially the stuff bit). So how did the steel all break up with heat ????. It was red hot when they were taking it away to be recycled (far too quickly imo)
Or are they saying it was that fire but it wasn't buring for that long was it ??
I'm confused is this still a debate, or a competition of low blows??
