- 18 Oct 2002
- HELLAS
12
Got a job as an erection
Revo stg2 remap running 9 boost-8 or 9 timing (according to the weather temp) (revo select plus controller settings(9 is max))
4bar fuel pressure regulator
Stock FMIC
Forge silicone turbo inlet hose
forge 006 bov
pipercross foam vector cone filter
bosch F5DP0R sparks
70mm custom made dp
63.5 decat and single muffler custom made cat back
Greddy Boost gauge
Greddy Exhaust temp gauge
Apexi Turbo timer
KW variant 3 coilovers
repainted rims
debadged honey comb grille and side grilles
autotest side skirts
Brembo drilled front discs to replace the stock 312x25mm discs
Ferodo DS2500 brake pads(car is equipped with galfer-seat sport 312x25mm 4pot calippers)
Goodridge high pressure brake lines
JVC Avx 810 head unit
pioneer 170 i speakers with crossover
and in about 2 weeks will be installiong some more gear which i have sitting in the living room
Neuspeed 180 degree thermostat
Evo heatshield intake manifold gasket
Rear anti sway bar by whiteline 20mm adjustable
Vibra technics dog bone
Toyo R888 semi slics
Audi S3 rear brake caliper+drilled discs kit 253mm (iirc)
12" helix sub
ESX amp
helix capacitor
blah blah blah...
hehe...after 3 months owning my car i was about to sell it an buy the leon cupra 2...man those cars reach 380 hp on remap, full exhaust and intake...
Leon Cupra K1 is only running 330bhp with exhaust and remap
http://www.millteksport.com/product.news.read.cfm?articleid=47
.Still drag racing a friends porsche 911 3200 325Hp from rolling 2nd up to 240km/h, my cupra is about 4 cars in front.
