Don't pay attention to all the macho men saying you don't need wriststraps and antistatic. It's good practice, might prevent a disaster and apart from bragging rights there is no point not doing it.
Remember that these components have built in redundancy to cope with partial failures. If you accidentally use up some of this redundancy due to sloppy building practice then you are reducing the long term life and stability of your components.
Static does damage components and I have seen the photomicrographs to prove it.
Luckily in our damp miserable english climate static isn't such a big issue, unless it's very cold and dry or very hot and dry, and you are not running around on nylon carpets with nylon socks on.
So you will "get away" with not using sensible static precautions as people have said.
Incidentally the trick is to have your electrical components at the same potential as yourself when working on them - this is not the same as earthing yourself then picking up the components. Do a bit of googling on this if interested. That is why it is best to have a wrist strap attached to a static mat and put all your components on the mat. This would put you and your components at a floating potential (SAME!). Alternatively you can earth the mat which puts you and the mat and components at earth potential but this is not necesary.
