Just ordered a 1Tb WD EVCS drive
I dont have any recordings to transfer over to this 1TB drive.
I will use an internal SATA connection on my PC to connect the removed SkyHD drive -> make an image of it -> remove drive -> install new 1Tb drive into PC -> copy image on to it
Can i do the above using Copy+ ?
Yup, should take no more than 30mins, including fiddling around connecting/disconnecting.
Check that you have the correct screwdriver, you need a T10 torx screwdriver. I know B&Q do one in store, but check stocks. I did get a set of the security bits from another store, but the screws holding the lid on are recessed about 70mm into the lid, so you need a torx t10 with a long thin shaft.
Watch out when installing the new drive as it is longer than the drive in there, so will be a very tight fit. You might have to bend the casing whilst holding it to get teh screws into the new HDD. Plus the power cable from the back of the box might be trapped between the hdd and the edge of something else. Not something to worry about but just giving the advice so you arn't shocked.
