- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
My entry...
Did a little business orientation into where Overclockers is going - and came up with the following concept logos:
Vectors of course available.
Notes
- Identity
Given Overclocker's expansion, have suggested backgrounding the union jack whilst keeping the colour tones. In short, you keep the brand recognition and don't force a UK-centric limitation on your brand.
- Full branding
Whilst have designed OCUK options to be used in short-hand locations, felt the full OverclockersUK brand is worth maintaining to ensure reinforcement of the niche. (It's a great brand by the way! **certain major uk pc company** has been really struggling with brand identity constraining their expansion - given they're not wanting to simply sell PCs anymore. 'Overclockers' is a brilliant brand that'll give you space to expand into almost any market (within reason of course - Overclocker's Bread might not work!)
- Palette
Have avoided any 'fashionable' elements (eg gloss, reflection etc) on the logo itself. These can of course easily be added, however was aiming to create a brand that'd stand the aging process without becoming dated as well as being totally transferrable to any format/colour range etc.
-Website
I also felt you might raise the branding out better on the homepage with a lighter header element, this'd be a two minute tweak to your html/css - so have included an example above. Hopefully you'll see it'd be a very easy way to really increase the brand visibility and freshen up the site with very little effort. (Just a thought!)
-Brands
Should probably note I'd recommend the top centre brand for external promotion, site header etc (ie as your core brand). The other two are optional for internal use/forums etc (ie people that already recognise the main brand). OCUK as a brand is likely to be problematic (conflict with other brands) and doesn't convey the same strength/concept as the main brand...
On another note...
Ok, as design, branding & web management has been my job for quite a few years now, I'd also like to say I have been highly impressed with the standard of entries - have seen plenty of £250+ bids where the range of entries are far worse. Know there's a few negative posts, but can only assure you the whole industry isn't like that - there's a hell of a lot of talent in this thread - so I'm not going to adopt any 'high and mighty' stance - there's some great stuff here, more than happy to lose. ;o)
However, OC has been my place of purchase for many a great upgrade over the years, so actually even without a prize I'dve be happy to give them a favour back.
Anyway, best of luck to everyone and at the very least I hope the above advice is of some use to Overclockers as they continue to expand...
Notes
- Identity
- Full branding
- Palette
-Website
-Brands
On another note...
I think I'm in love with you
