The blue tube is 7/16 = 11.1mm
come on people, keep up![]()
Come on, read the thread
Edit Just to reiterate for CK61938 I am talking about the hole on the *fitting*, not the *tube*.
lol...no...sorry it is 1/2" exactly...no bigger no smaller...
Aha, so it *will* at least slide up and down 1/2" OD tube, which is what you want, although it will be snug.
Snug is good...snug can be very good...I like the idea of a snug fit...just wish I had a woman like that![]()
Edit: not sure I'd agree with the woman analogy - but lose is bad in both cases
Are you sure you are using the right hole there? Anti-kink coil may come in handy in those cirumstances also.![]()
when I go to Dublin next weekend![]()
Is that what they are calling it now? First time I've ever heard it called that. Oh, Dublin, the place. Gotcha. Thought it was some new slang term to confuse the mrs.
Barbs are pointy things you push the tube over, so the inner diameter needs to match.
Compression fittings bite down on the outside of the tube, so the outer diameter has to match the fitting.
that's my main gripe the 8 PIN power connector...do OcUK even do such things? cos I do need one...I dont think one came with the PSU when I ordered it but I will check.
And thanksmuch appreciated to know someone is watching
