Any of these 50% discount coupons floating around then??
The vouchers haven't been given out yet. End of the month, iirc
Is there any webpage that shows the patch notes?.
Actually managed to get some multiplayer games last night, had good funSeems the latest patch sorted some of the matchmaking issues.
Frogboy said:* Additional connectivity optimizations and improvements
* Lord Erebus: Bite's Mana Cost increased, Damage decreased, Armor Reduction decreased
* Fix for looping audio track after leaving character select screens
* Fix for audio volumes not being reset on restart
* Adding /skipintro command line to bypass intro movies
* Players will remain connected to facilitator if they fail to connect to other players, provided they can connect to the host. The host ultimately can kick people with problematic connections to others.
* Favor Items fixes, but still some assorted issues that should be addressed in the next update.
* Major optimizations to audio on low fidelity settings
* Fixed bug that occurred if you used an ability after issuing an attack command. This is the "won't chase the demigod I clicked" bug.
* Sending deltas for partially completed achievements.
* Each player now saves their own achievements and favor items
* Fixed partial Achievement saves bug.
* Fixed a bug that occurred if you accomplished an achievement in game.
* Fixed a bug in disconnect dialog that would try to update it even if we had determined we did not want to show it
* Changed resample rate to 24k in Low settings
* Delayed FMOD initialization until audio LOD is set via options
* Disabled hitbox interference from announcer messages.
* Life's Child no longer removes Inner Grace (Sedna fix)
Frogboy said:We will probably have another small update tomorrow as we continue to refine this.
Finally they appear to have cracked the connectivity issues![]()
Quick tip to all you new players, dying is about the worst thing you can do in the game. It puts you out the fight for 20 - 35 seconds, stops you accumlating gold during the duration and gives your killer a fat pile of money to spend on upgrades. If in doubt, run away.
