The All New Desktop Thread, Images No Larger Than 800x600
Anyone had an issue getting that rainmeter hud to work, installed and extracted to the skins folder but it does appear in my list?
Yes! Only had a quick try as i was busy doing other things but i only had the choice of the two original ones...
Edit: nvm, in my haste i installed rainlender not rainmeter.... lmao.
My main system:
Can anyone suggest a system monitor skin that might go with this? Nothing fancy, just CPU (quad)/RAM/network.
My main system:
http://upload.mattus.co.uk/data/desktop_2905.jpg[IMG]
Can anyone suggest a system monitor skin that might go with this? Nothing fancy, just CPU (quad)/RAM/network.[/QUOTE]
As you have rainmeter, I would suggest either hud.vision or enigma, both found on deviant art. You say quad core, so you want to see the load on each core? I can't remember if either skin allows you to do that straight away butI've done that on my dual core, so I could post the code if needed.
OK...I have the 10ft HUD skin working ok on Rainmeter, but I can't seem to get the weather gadgety thing working properly. It's just tells me the temp and displays "N/A"
is there a config file I need to download/create?
edit: sorted it. but i won't bother with the weather. if i want to know what the weather's like i'll look out the window.
So, Objectdock or no Objectdock? What do you think? I just cant decide, lol.
Not sure if i get on with it or not, ill give it a go for a few more days.....
With?
Or without?
It's all about aesthetics. There is little doubt that a dock can look better than having a desktop riddled with icons and a double layered taskbar with reams of quick launch shortcuts.
