they are trial keys?
NathanE or Burnsy, is this correct?
The first link is broken, use this one:Is the link still working? getting a cookie problem on 3 different computers....
That was a sneaky edit timbo, I sought clarification for this nugget because you posted up that the key only lasts for 3-6 months.
Yes having a good look at the EULA it seems the keys are lifelong keys. They are NOT trial keys as in they will NOT expire.
However, they are meant to be used as a trial purpose so think of it as a trial which does not expire and will always work.
If you use it for more than testing then well thats between you and microsoft
