Just received a £2.50 case from Ebay for it, a rubber one - fits absolutely perfectly and everything is still accessible, great buy and would recommend it to any of you!
I easily unlocked mine at:
http://www.unlock-samsung.net/EN/unlock+Samsung+I8910.php
scoopex - will this only work with xp? Great job fella
I saw on that share4gsm site that he was using Vista X64, be interesting to see if he did it on Vista or used an XP machine.
You can get the firmware off another site for free but it does only work on XP.
What exactly does de-branding do?, does it offer any new features with the new firmware?.
Ive just ordered the phone from orange as its back in stock, will be here saturday.
Not seen it free....
Changes we have noticed with the new firmware:
•Phone is much faster
•Youtube and all widgets are now available
•Camera now saves anti shake and contrast, sharpness settings.
•GPS lock seems faster. (I can get full signal inside my house!)
•Rid of all the horrible Orange branded crap.
Cool
If your after a case the ones off ebay for £2.50 aint bad
are you allowed to give out the name of the website that has the firmware? Does anyone know if getting this done will void the orange warranty?
De brand you Samsung Omnia i8910 HD - ALL FILE HERE FAST DOWNLOAD
Here are all the latest files for you to de brand your i8910 HD to the latest firmware
Flasher - http://rapidshare.com/files/242795459/www.ipmart-forum.com_Symbian_ROM_Flashing_Tool_v1.50.rar
Firmware - http://rapidshare.com/files/242802318/www.ipmart-forum.com_i8910XXIE6.rar
Drivers - http://rapidshare.com/files/242800543/www.ipmart-forum.com__drivers_manual.rar
Use the guide already on here for an easy flash and save 15 euros.
Some guy posted it over at the samsungi8910omnia forums, got deleted.
But I managed to copy and paste the links! Happy days!
WILL ONLY WORK ON WINDOWS XP AND I TAKE NO RESPONSIBILITY FOR ANY DAMAGE OR ERRORS TO YOUR PHONE
Once downloaded; extract each rar file to its own folder.
Install Drivers & run exe's
SSDN_V1.1.808.7165_SETUP_whql.exe ( Run )
SAMSUNG Mobile USB DRIVER(4.40.7.0) v1.6 > setup.exe ( Run )
PHONE_driver > Setup.exe ( Run )
PDA_driver > IBootHostUSB.inf ( Right Click / Install )
Running Symbian ROM
Symbian ROM Flashing Tool v1.50.exe ( Run )
In the top left corner heading "File Info" you need to point the top 3 paths to the corresponding files.
Please see the PDF share4gsm_GT-i8910_SVCM_how_to_download.pdf which highlights the other options that need ticking, when i ran this Flash TOOL all the options where already ticked by default.
Make sure your phone is off, and the USB cable is out. Hold down the VOLUME UP and HOLD button, while turning the phone on. The phone should now go into boot loader mode, with a blue screen.
Now its time to plug in your USB cable.
to the top right is Connection and Progress INFO, if your phone is recognised and the drivers are installed correct No1 PDA should display a COM Number.
Your phone is now ready to Start the Flash.
Double check all your settings, and then click "Download Start"
guys, just want to know when you guys mentioned about de-brand, does that mean that the phone will become network unlocked and I can use it on different network?
momagic, does the files that you've got there work well?
