- 28 Jan 2008
There's been a few updates and such, so is it worth getting now? What's the multiplayer community like? Will it run ok on my PC (1280x1024)?
I installed GTAIV to test run a E2200 (@ 3Ghz), 4GB PC8500 & 3850 512mb, was borderline unplayable at 1280x1024, even with 3rd patch...
GTA 4 is a good game, one of the best in the GTA series. However the PC port is absolutely dog-**** bad.
If you want a better sandbox style game, I would recommend Saints Row 2. Mmmmmm!
NO NO and NO.
Sr2 runs even worse than GTA IV. Beside looking 100 times worse (it looks like vice city), having rubbish physics, having ANNOYING poor sound quality and generally being a big fail. It's far more repetitive than GTA IV imo due to having to get the respect thing before moving on to proper missions.
But SR2:
It looks crap.
It moves crap.
It runs crap.
It sounds crap.
The draw distance is appalling.
The car handling is jokeable.
Your ears hurt from the sound quality of the radio stations and tire squeeling sounds.
The city is small and a bit one toned.
I'm sorry but your wrong, I much prefer the pc version to xbox360, providing your pc can cope it looks and plays a lot smoother and looks miles better. The port could have been smoother, but then it was coded/written for to run on xbox360 which is 3 core based iirc? It is not perfect, but it's far from **** bad as you so elegantly state.
I'm gonna give it a go.
Only thing is I have no performance benchmark figures to compare it with how it ran the first time around, but I guess I will know straight away whether it runs any better the minute I start playing it.![]()
Because of your cpu, I'd really recommend AGAINST using any vehicle density higher than 10-15 ish...
I had an E6420 @ 2.8 ghz at release of gta iv, upgraded to a q9550 after and it went flying.
is it worth going back to gta:sa on the pc/ i never got round to it (did play it on ps2 but don;t have it any more)
