Best mouse?
17 Aug 2007
Hey dudes;
im posting to inquire on what you think is the best mouse out at the moment.
Ive previously owned a Razer Deathadder and thought it was excellent. A little bit pricey, but well worth the money (I brought mine when they were ~£45). Had a small accident with the mouse though, and need to buy a new one.
Should I get another Deathadder,
or is there something better?
Many thanks in advance chaps.
I have a DeathAdder and a G5. I think the G5 is better, but thumb buttons on the DA are in a better place.
I've had a few Razer mice, Diamondback, had terribly squeaky buttons, a common fault it seems that meant taking it all apart and sanding down under the buttons and the flawed Lachesis which had terrible cursor drifting and would often become sluggish needing a profile reset. One solution by Razer was to peel off the label around the sensor! So if you like to dismantle your mouse get a Razer.
Also, Razer mice seem very fussy about surfaces.
Just moved onto the Logitech G5 and it's a great improvement in precision but a DPI LED was faulty so that's gotta be exchanged, I have no luck with mice!
Seeing how expensive these mice can be I think Razer is over-rated overall.
My favourite is the MX1100 - its not exactly advertised as a gaming mouse - but it does it very well. It does not have an infinity-billion DPI like some - but I find 1600 on my 1920x1200 screen to be perfect. It feels very responsive and the scroll wheel has to be used to be believed. Overall - awesome.
I've used the Deathadder, diamondback 3g and my brother's g5. Personnally I have the db 3g and love it but the deathadder is great to use as well. If you're used to it, then get that again. The g5 doesn't compare as well in my opinion.
Used both DeathAdder and Copperhead, they are both very very good, but the Deathadder fits better for me.
I also tried the Steelseries Ikari Laser, but paint started peeling off after 6 weeks so I sent it back and gone back to Deathadder.
Normally your advice would make me cautious, but judging by the thread, it seems you must have just had bad luck or something ;)
Though I do agree these damn rodents arent easy on the wallet.
Cool mouse, but im going for a wired option.
Judging from the thread responses, im going to opt for another Deathadder.
Cheers for the help guys.
Well my problems with Razer mice are very common. Check out the razer blueprint forums and many had the same problems I had. And worse of all, Razer wasn't that helpful in solving the issues.
Logitech mice can have faults too, but the tech support is so much better.
There is no mouse apart from the one that feels best in your hand, i would preferably go for a reputable infared mouse such as the Mx518 or the Deathadder (which i am using now).
