will this lappy play l4d and the new call of durez 2? at a decent rate?
Its plays L4D really well for me 1366x768 high no problems. No idea about call of durez 2.
Nice one just got back from shopping with the mrs she let me have one guys said in store it was and end of line product...just got to strip all the rubbish nowpaid £547 anyone tried overclocking the 9600mgt with riva tuner?
Well today i brought the Acer 6930 for £600
Specs are,
Intel Core 2 Duo P7450 2.13Ghz 1066 MHz FSB 3mb L2 cache
9600GT NVIDIA 1Gb Dedicated
320 GB SATA
4Gb RAM DDR2
16 inches screen
Windows Vista Home Premium
Great spec for the price just setting up now![]()
I notice there is no recovery disk with it so I am assuming now... you have to make your own? Think I may do what you have done BEN UK
You sure those are right, I can't find a Acer 6930 with a 9600GT?
Hello,
I have had a Acer 5051 laptop for nearly 2 and a half years now, cost me £450 and its serviced me well but its time for a upgrade.
Looking to spend no more than £500 really. Hoping to get £100 second hand for the Acer to but towards the new one.
Looking for best performace for £500.
Hoping to beable to insall steam on it and play CS: Source at good playable frame rate
What would you recommend for £500 ?
Thanks Ben
Specs are,
320 GB SATA
4Gb RAM DDR2
16 inches screen
Can't find this spec anywhere.
Infact I can't even find one with 320GB.
The best spec I'm finding is:
2.0Ghz Core 2
4GB Ram
250GB HDD
1GB Dedicated 9600m GT
Did you get yours in the UK ben?
any of you Acer owners come across issues with CPU throttling when playing games? (ie it'll become laggy ingame)
I got the 6930G
P7450 2.13ghz CPU
4GB Ram
9600M GT 1GB GPU
320GB HDD
Nice machine although its running on a 32bit OS so im not getting full value, I have to send off for the disk I believe.
think thats an end of line model..mines the 250gb t6400 jobbie 4gb ram 9600m gt
I haven't noticed any throttling at all..
Though my housemate has the same machine as me, and was running Furmark and Prime at the same time to calibrate a battery - on the couch - on the hottest day this year.
The machine didn't throttle, it just shutdown.
I'd have to say that's an extreme burn test though, and it's nice to know the machine shuts itself down rather than melts!
