It must be idiot season ...
I've got a guy from a kebab shop complaining that his camera system has packed up and it should be replaced instantly under warranty.
I go and check the machine and it's not been cleaned/touched in the 4 months it's been there, the panels are caked in grease (even the front usb ports are covered in it!), had to pry the side panel off with a screwdriver as it was glued shut with oil, case fans were running with oil, cpu fan was clogged, no airflow through the psu, etc, etc.
Asked him why it had never been cleaned (even just cleaning off the exterior fan grills would have helped) and he said thought it might break if he touched it. Couldn't understand how so much oil was in the pc as it's on the far side of the shop from the griddle/frier/etc.
I've found out from one of the staff that he turns off the extractors to save money.....
Just need to leave the case to drain for a few days and i should be able to get a few miles out of the drained fluid.
