Will the Mad Catz Xbox360 Street Fighter IV Arcade FightStick Tournament Edition plug into a PC and work ok?
Yes, I have a PS3 Madcatz SE stick and it works ok, the 360 ones work ok too.
I have a spare SEGA USB pad because I bought 2.It's brand new and still sealed in the box, the one I opened was tested and works with PS3 and PC.
If anyone is interested just email me.
PS. If this isn't allowed can a mod please delete!
I won't take it off your hands as I'm not in the UK, but can you tell me how these pads feel? I usually like to try peripherals/controllers hands on before I buy.... Recommended?
It's very small and light, but definately worth it if you can pick it up cheap. It's decent enough for games like SF because the d-pad is very good. I haven't used mine that much so I can't tell you how good the quality is or how long they last but for a cheap controller just for SF, I would get this.
If you want to pay quite abit more then go for the madcatz ones but they have had so many problems it's probably not worth it, best off just buying a fightstick.
i would only buy this if it was in the bargin bucket for £5.
Been playing the game and its pritty crappy imho.
the controls for instance dont play this game with a 360 controller cause its hard as hell to pull the moves off.
it will be constantly all maxed out at 1920x1200 all in game settings maxed 8xaa 16xaf
and when you get to certain maps your frames will rapidly drop from 60s to 30s
then once that happens its like playing in slow motion lol and no way to fix it untill you restart the game, then it happens again on the same map or on certain maps....
mine is hopefully arriving tomorrow 19.99 shipped
