As others have said, the modern diesels may be fast but they still run out of puff very early in comparison to a petrol, they don't sound as good and their heavy weight affects both throttle response and handling in comparison to the petrol. The throttle response must be the most annoying aspect for me though. Floor a diesel's throttle at idle for just half a second and all you will get is a lazy blip of the revs after a small delay. Do the same to a petrol engine and its instantly half way to the limiter!
I just don't really like diesels for sporty driving. Great in town when you want to surge past someone efforltessly -same as automatic gearboxes. But for pleasure, no thanks!
Plus I don't trust modern diesels as far as I could drag one. Old ones were basic simple machinery that lasted and lasted. New ones are so advanced and have so many electronics and other bits to go wrong - turbos, injectors, high pressure pumps and other stuff which is simply not found on your average petrol car. OM615 > OM611
