Can you get out the room?
what do you do with the radio thing? Some people were sayin about a music box before? I've not come across that yet?
I'm movin the sliders up and down and pressin play then eject but nothin is happenin, tried prying the cover off with the knife but nothin
Use the sliders to get five high beeps. This will open the box.
Fiddle with sliders and listen for any changes it makes.
I've opened the safe both panels. I've found five UV clues. And.... I'm stuck. Can't figure out what I'm supposed to be doing with any of them. I think they probably relate to the screws I haven't used yet but can't find anything to do with them.
Hint?
Clues show you how to open the panel to release the keys. Cube is a good place to start for the right hand panel. ;)
I'm officially completely stuck.
I have two batteries, the test tube, the gold bar a key and a note. I have both panels and the picture open, but no codes for anything. No knife so can't do anything that needs that, and can't see any way to get into the briefcase.
Look behind the suitcase (it's an awkward one to hit)
Hint?
The UV clue is the safe code.
edit: xL / xR
x=number
L/R = Left/Right
