I cant figure it out though, does it require a knowledge of how to play the piano?
Yes. You need to know what keys are for which note on the piano. ( Google is your friend. )
what do you do with the radio thing? Some people were sayin about a music box before? I've not come across that yet?
I'm movin the sliders up and down and pressin play then eject but nothin is happenin, tried prying the cover off with the knife but nothin
Clues show you how to open the panel to release the keys. Cube is a good place to start for the right hand panel.![]()
I'm officially completely stuck.
I have two batteries, the test tube, the gold bar a key and a note. I have both panels and the picture open, but no codes for anything. No knife so can't do anything that needs that, and can't see any way to get into the briefcase.
The UV clue is the safe code.I've opened the safe both panels. I've found five UV clues. And.... I'm stuck. Can't figure out what I'm supposed to be doing with any of them. I think they probably relate to the screws I haven't used yet but can't find anything to do with them.
Hint?
I've already got one item from there - is there more than one thing?Look behind the suitcase (it's an awkward one to hit)
Already done that - got into the case now.Sorry, being dim. Look at the picture. To the left.
