ARRRRRRGHHHH Armpits are on teh fires!
When you first start using it, it can sting A LOT (even small amounts). I couldn't sleep with it on some nights. Dab your armpits with a slightly moist flannel (it shouldn't leave any moisture on your armpit though). It will still do the trick but sting less. After a couple of months or so the stinging will subside and eventually you won't even feel it at night :)
I can't wait to try this out :o
The people that think BMI is effective? Doctors are far from flawless, they dont know everything.
im betting they know more about driclor than some randomers on a forum do though.
as someone else said, this stuff will of gone through mass clinical trials from when it was prescription only.
this stuff really cant be good for you, especially if you do lots of exercise, we sweat for a reason no?
You've never used an antiperspirant? The majority of the population does.
Driclor, Odaban et al. have exactly the same active ingredient just more concentrated.
The goal is not to prevent thermal regulation induced sweating but to prevent excessive sweating from specific areas.
I can be freezing cold outside in the winter but still have damp patches under my arms when using a standard antiperspirant.
Yes, using it liberally over the whole body would probably cause you to overheat and die in the summer.
Oh right I see :p I just stick to dark coloured tshirts and pile on the deoderant. Some days are good, some are bad :o
Sorry, didn't know you had this incredibly annoying problem :o thought you were just poking fun.
I didn't make the whole process sound particularly appealing but it really isn't too bad (I was just putting too much on really). Get it sorted mate, you'll be glad you did :)
I've never found a particularly good anti-perspirant until yesterday. I'm not fat and I don't sweat a lot, but in conditions that DO make me sweat, nothing seems to work.
On Rotty's advice I picked up some Mitchum from Tesco lastnight and it seems to be spot on. The office was horrible and humid all day and I'm bone dry. No discomfort either.
I don't find Mitchum works any better than Sure, Lynx, etc personally. Instead I'm working on the psychological reasons for my sweating (acting relaxed in specific situations, etc) It's healthier, costs less and seems to work better for me. But again this is just personal experience, I haven't tried Driclor or Odaban and don't wish to.
Working on it psychologically sounds interesting. It's not nervous/tense situations that make me sweat though, just hot and humid conditions.
I have used Sure for a long time as I thought it was the best I was going to find. Annoyed I didn't try Mitchum sooner as I find it much more effective. But everybody is different, so what may work for one person won't necessarily be effective for another.
Ah well the psychological route may not be as effective then I guess and it would explain why you are getting more success with the anti-perspirants than I do. It's always worth a shot though! :D
Tried most of the stuff myself including Driclor, but found the best thing to use (best effects after prolonged use) has been the new Lynx Dry range - Very good indeed!
