Man of Honour
- 29 Nov 2008
- London
Go for the OCZ Vertex personally..
same drive, different sticker, cheaper price.
Does the GSkill support TRIM?
The vertex gives you 120gb and reserves 8gb for SSD management. The gskill gives you the full 128gb but it will more likely wear down faster.
No, they have the same formatted capacity.
http://www.hardwarecanucks.com/foru...ews/18195-ocz-vertex-120gb-ssd-review-16.html
"All Vertex 120GB drives have sixteen 8GB chips for a grand total of 128GB space …just like the Falcon. However, OCZ has firmware limited the amount available to you the customer by 8GB. This on the surface sounds like a bad thing but the key thing to remember is to ensure the longest lifespan possible you have to leave enough room for the wear leveling algorithms to do their jobs."
On the Vertex Series the naming convention reflects this and the 30 is equivalent to 32GB, the 60 is equivalent to the 64GB and so on.
Vertex is 64GB, they advertize it as 60GB because of the known discrepancy. G.Skill just named their SSD's like every other hard drive manufacturer does.
I have reserved the cash aside for a vertex. If nothing will supercede them in the next month or so, one of them is mine![]()
Hardwarecanucks is a respected site that doesn't bow down to marketing pressures and whatnot. They tell it like it is. And if you bother to read yes they are the same capacity, but OCZ's firmware reserves space for SSD management to increase to life of the disk. Reading specifications and testing out what things actually are isn't the same. Call it due diligence. Yes we all know about the 10 base 2 etc since the dawn of silicon.Yet another review article talking out of its bum and not bothering to actually check the specifications, and their theory based on the apparent specifications, before writing it.
http://forums.ncix.com/forums/index...03&product_id=38191&msgcount=15&overclockid=0
They are the same capacity.
..well there's the Vertex Turbo, which should currently be available to retailers so they should start popping up soon, never mind any others that turn up.
just received my G-Skill 128gb ssd today ...install windows 7 onto it .....starts up in around 24 seconds ....well happy with it .....lot more responsive too![]()
