- 19 Feb 2007
- Sol
anyone by chance know where i can buy pull up bar frames, ive seen the ones you put in but i dont trust them, any help is appreciated.
http://www.jmldirect.com/product.asp?pf_id=I8700&src=froogle
This actually seems to get good reviews. Assuming that's what you mean you should probably post in the Sports section.
i dont trust nothing you hook over a door.
. Been up for around 2 years and supported over 100kg though
Are you after more this sort of thing:
http://www.purefitnessandsports.co....ports-vkr-pullup-dips-powerstation-p-511.html
I built a wooden A-frame and fitted it with an barbell bar to make something similar, bit of side-to-side motion though. Been up for around 2 years and supported over 100kg though
That seems like overkill to me...That is exactly what ive been looking for thank you very much![]()
Why not? Simply a case of leverage here, if you're pulling down on it then it holds more tightly onto the doorframe so no chance of slippage unless your entire doorframe goes.
no its just good manners.
I wrote about the powerbar in the gym rats thread, it's a really good bar!
i use my garage roof just jump up grap it and then do wide grip pull ups
