Hi guys,
The HDMI connector functions properly but thrust me .... at 1080p my PS3 looks gorgeous on my EPSON projector, while on this display i can count the points where an oblic lines brakes..it's really unpleasant to the eye...
For me this is a poor quality device for the many u end up paying...
Could someone please tell me how wide the base is? Thanks!
By base you mean the stand right? It's 10.5 inches wide
Yeah- cheers for that! Typically tho i've just read about the issue with hdmi for pc.... so that might make me look elsewhere. Not the end of the world i admit but annoying.
My graphics card has a VGA,HDMI and DVI output on the back, and i'm connecting two of these together as dual monitors (Which is quite impressive with a total resolution of 3840*1080)
Atm, i'm using the VGA cables that came with the monitor and a DVI-VGA adapator i had to connect both VGA cables to the graphics card.
I'm aware that I will get superior quality using the DVI input on monitor, and I can easily use one of the DVI outputs to do DVI-DVI on one of the monitors.
Would i get the same quality using the HDMI output on graphics card, with a HDMI-DVI adaptor to also use the DVI input on the other monitor? Reading the comments on this thread I've noticed many people saying that using HDMI input on monitor for PC is inferior to the DVI input for PC. Will I get the same quality doing HDMI-DVI as simply DVI-DVI?
i have just ordered one of these to become my new primary display, and have my LG 227WTQ as the secondary display!
what a good monitor, cant wait to get it on tuesday![]()
i see from one of the above screenshots that the freeview tv picture is 4:3 aspect ratio, possible to set to 16:9 or 16:1O?
also confirm that PC via DVI and PS3 via HDMI looks spot on?
really need a decent multifunctional screen(tv) this is looking like the best contender
thanks
How are the vertical viewing angles mate? Do you know what type of panel it is? Looking at getting the 27" version...
