- 22 Mar 2009
How much cooler is it over the best heatsinks, and is that thing noisy?
i read an article of it saying its pretty good and cheap aswell, 70 quid or something?
It not bad noise, I can hear a little but not as high like a dreadful titan fan is worse noise in my case. Yep I brought it for just £53 ! A very good bargain and it work very well.
i find it hard to believe it's cooling that well especially for that price.. but get us some temp screens asap![]()
I use 2 fans because the fan come with antec 1200 as if I removed it off, then the radiator won't fit by the case next to fan, so, I turn the fan round to push intake with h50 fan and it work pretty well. That's the reason I use two fans together.
Do you have those back fans set to low-medium or high? i feel high is noisy, low is decent and medium is only a little louder.
Those are great temps if the case fans are set to low or medium
was gonna get new thermlight soon, think will get 1 of these, £53 + del, ( or if Oc get in next 10 days ) these look good, easy to set up ect![]()
Temperature is lots better at idle 34, 35, 34, 35 and full load for 2 hours on prime 95 is 68, 66, 64, 64 for 4Ghz at 1.31vcore
I do apology for my mistake on these temperature because I forget to set TJMAX at 100 on coretemp as it was set at 85 before. The correct temperature is at idle are: 44, 45, 44, 45 and full load at 83, 81, 79, 79 on vcore 1.31v
