- 23 Aug 2008
Having read the bit tech review I'm going to try one of these
Looking forward to the results Rab, looks a decent enough unit.
Not as good as a decent water cooling setup but its not expected to be, but if its on par or near enough to high end air cool then i may sway to one of these when i upgrade soon.
Ok guys, based on testing of two of these units we are getting in a LOT of these. (Read hundreds!)
We will do a proper review when we get chance but you will not be dissapointed, I have publically eaten my words to the Corsair reps on the performance of this unit.
Here is the news post and pre-order info: http://www.overclockers.co.uk/news.php#1939![]()
Is there any chance for you to test out 2 x 'Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan' as a push pull with H50 with a review ?
We are looking into a Push Pull Apache fan setup which is comparable to what you are looking at.![]()
Good video here of H50 review: http://www.youtube.com/watch?v=DQxw...ucts/h50/default.aspx&feature=player_embedded
It's mounted on the back which is probably why it didn't fare to well. dunno if it is pushing or pulling aswell as you can't really see.
