Indeed, if 0.9r is written to be less in value than one, then surely the logical conclusion is that... 0.9r is less that one?
Not that I'm a maths wizz or anything, naturally.
You're not allowed to apply logic, the maths bods don't like it
but if you wrote 0.999r < 1 youd be wrong.
It doesn’t, it just goes on and on and on.........
Ah, then you'd be utterly wrong.And what I was saying is that 0.99r is not the same number as 1, it is simply a limitation of the base 10 number system that leads us to say they are so similar, they might as well be the same number in practical use.
What, like 0.5 and 1/2? Nice watertight argument there, Sherlock!0.9r and 1 are not the same number, else they'd both be written the same way![]()
Why?
As long as the first digit never reaches 1... the number will never be equal or more than 1.
They represent exactly the same real number. As do 0.5 and 1/2.Hence the wink. It's still right that 0.9r and 1 are different numbers.
Why not?
theres quite a few proofs that 0.999 = 1, believe it. (or search wiki theres a few proofs on that page if you dont)
they represent the same real number.
then why are we arguing?
Clearly there's no telling you. I asked before, but you must have missed it. From what authority do you speak? You seem to think you know better than every mathematician on the planet - I'm wondering where your confidence comes from!It's a very similar number, not the same![]()
I was actually agreeing, in a roundabout way.
Post a proof and I'll show why I think it's wrong then.
