- 27 Jul 2005
- The Orion Spur
i thought between the 2 the 360 version was much better.
Really !?!!, I'm sorry but how did you come to that conclusion ?, I wouldn't normally jump on a comment like this but for once I actually think the PS3 got a decent version of an UT engine game that competes with the 360 quite competently for a change, B3D say both versions are running @ 720p, the frame rates seems to be about the same, screen cuttings seems to be about the same, textures look identical, in-fact the only real difference is that it appears that the 360 version seems to have selective 2xaa and subtle SSAO.
PS3
360
PS3
360
PS3
360
PS3
360
Technically the 360 version is better, but this time around the differences are negligible and the only thing that should sway you is your controller preference and whether you want the extra content or not.
, yes people have said there is a distinct difference between the two in terms of the gamma so when comparing them that needs to be matched and also the TV settings etc, once that is done they look pretty much the same, although like I said the 360 version does have selective 2xaa & SSAO so it is technically better, I'm just impressed with how well they handled the PS3 version this time, especially considering it's the UT engine.
