Anyone care to make a youtube video
Of what?
Of what?
It's basically in a massive white box compared to the SSDs size. Then the SSD is in some anti static plastic bag with a bitter of paper ontop to fill the huge waste of boxing![]()
Of the Crucial HD being unwrapped!! lol
hey guys can you check this benckmark plz and tell me if it looks ok for a 64gb version, im a little worried because i didnt actually instal win 7 i installed an image of win 7 using acronis, so i dont know if the OS is maximised for SSD
what you think ?
if alignment issues matter to you and you intend to use acronis true image - dont. At the moment if you do it will not give you the right offset for proper alignment but the same offset that you would get creating the partition in XP, regardless of the offset on the source partition. Just a note of caution.
im abit baffled by all that
but i need to ask
ive just transfered an win 7 image that was created on normal HDD using acronis and installed it onto my SSD , will all those win 7 functions still be turned off automatically ? or will i have to do it manually ?
1. Open a cmd box, type Diskpart
2. List disk
3. select disk ? (where ? is your SSD, usually 0 for the main drive, if you're not sure check in disk management, that's right click the 'computer' icon)
4. list partition (will display a list of partitions and their alignment offset)
5. What does it say for offset? (Default on mine is 1024 ~ 1048576 bytes)
6. exit
7. fsutil fsinfo ntfsinfo ?: (type this in with the correct drive letter)
8. What does it say under 'bytes per cluster'? (normally 4096)
9. exit
The 'Partition Offset / File Allocation Unit Size' should be an Integer (whole number)
Default is 1048576/4096 = 256 so all is well.
Its bad form to quote oneself, but from earlier in the thread. What do yo see if you check the details above?I did a clean install of windows 7 rtm on my 64gb drive and I also have wierd results although still much better than yours.
I didn't have much time last night but it appears that windows 7 has set some really massively high cluster size when formatting the disk. I'm going to have to do more research.
HDTune shows my performane to be a zigzag up and down between 220mb and 50mb throughout the whole drive so there is something not right.
Wanna bet, see if this helps.I suspect, then, that making an actual clone of the drive with Acronis (which involves backing up free space as well) would not have alignment issues, as long as the parent drive was aligned correctly.
Wanna bet?
