I've always had problem running the SLL option, works when I take it off. I've personally been running it without for many years, is there really a need to enable it now?
Although Usenet is a plaintext protocol so if you're using it for the dodgy stuff in alt.binaries then you should certainly consider it, I'd imagine that Usenet will be where the media companies will target when they're done with torrents.
Anyone currently having problems with astraweb? I have been using it fine and the suddenly i am noticing in the log it is getting messages about username or password being incorrect.
