LOL! Sorry, It just seems better to me! I didn't see any benefit of the Q6700 and they run hot as hell![]()
BS
BS means?
They dont run "hot as hell" I have mine at 3.6ghz and it doesnt go over 65 C with an arctic colling freezer 7 pro!
Bull****
bull ****.
He is understandably annoyed that you are refusing to take any of the advice in this thread, despite that it will solve the problem and leave you with a superior system. It looks like incredible laziness on your part which ****us people off who spent time advising you.
This is not an inadequate heatsink. I'm going firmly with user error, either you clocked it quickly and lazily or you mounted it foolishly. It's quite rude of you to suggest that Ross knows less about the thermal limits of his processor than you do. Yes, he will have stressed it.
Well I am back to my E6600! There will be an as new Q6700 with a 1.25v VID going on ebay shortly!
I am not convinced with all this multicore witchcraft!
Have you ran Prime 95 for any length of time?
maybe my Zalman CNPS9700 wasn't upto it.
There's nothing about a Q6700 itself which could make your games stutter. The chip is essentially two E6700s joined together - it ain't witchcraft! If you're getting stuttering with four cores enabled, then the problem is going to be with the game or your configuration, not the chip.
If you run Prime95 my temps didn't go over 65c either until after around 30 mins, they then got as high as 78c! Which is for my money as hot as hell! Thats was at 3.6GHz. Thats why I reduced the clock to 3.4Ghz
Stop trying to be a smart arse.
Ross would have course stabilty tested his cpu.
You cannot even install a quad...so I would suggest thinking before you next post.
Then you have a wrongly seated heatsink or have bad case cooling or using far to much Vcore.
Do you know what you are doing?![]()
Stick at it. The Q6x00 is a great chip - why do you think so many people on here are still using them nearly three years after release? Because with a bit of (dead easy) overclocking, it still holds its own against the latest and greatest.
1.3v sounds too little for 3.4 to me maybe you should bump it up a bit.
Oh and, yes I stress tested it well.
