have bought it. it is addictive, looko at the time! just got a lexion 600 but its raining, so gutted.
i havnt played any cod4 at all today. that how good it is
http://www.landwirtschafts-simulator.de/releaseNotes.phpChangelog patch 1.1
Issues
AI Helpers
- fixed smallTipper trailer attacher joint
- disabled speed limit checks for AI
- fixed AI does not lower weights
- fixed refuel sound running infinitely (when moving slightly)
- fixed vehicle leave to fall through terrain
- fixed windrower for wet cut grass (smaller drop area, bigger tolerance)
- grass does not grow automatically again
- only allow cultivator and plough to work when lowered
- fixed cultivator/ploug/sowingMachine when leaving tractor and reentering
- fixed savegame using usernames with special characters
- fixed attachSound for mods
- fixed disabling lights when detaching
- fixed bale trailer tipping and filling
- fixed money saving bug
- dischargeParticles is now constrained to fillType
- fixed saving of bales
AI Traffic
- improved ai combine waiting for weather (driving back, stopping cutter)
- added extra xml attribute to attachable aiNeedsLowering
- improved ai combine (timeout, look ahead area)
- using ai back marker for turn reference
- added lower and raise events to ai tractor
- added timeout to ai tractor, to avoid lock when blocked by trees
- increased ai tractor terrain detail look ahead distance
- fixed tractor ai turning
- fixed ai combine turning when just emptied
- disabled threshing while ai is turning
- fixed ai tractor with plough
- added some rescue intelligence to ai combine (add force if stuck)
- tuned ai start after turning
Map
- fixed ai traffic correctly looping and less collisions
- fixed possible deadlock when a vehicle spawns in a junction
- increased brake force of traffic ai cars
GUI/HUD
- all empty fields now support ai tractors
- fixed dealer ground (pallet fork issue)
- increased size of upper barn door (for bales)
- changed barnElevator collision
- corrected floating straw decals
Input
- allow more help texts (up to 6 instead of 4)
- added reset vehicles question
- added popup dialog when player wants to delete a save game
- fixed the display of most of the keys
- fixed store menu with mods
- fixed speed level display for foliage wagon
- insert mods at the beginning of the shop
Graphics
- fixed gamepad input buttons
Fine Tuning
- added missing car lights
- fixed brake of attachables of attachables
- fixed grass tip trigger (plane moving up)
- fixed grainPlane settings
- fixed terrainDetail lighting
New Features
- increased lateral stiffness
- decreased number of bales created
- changed some trailer damper values
- increased camera max distances
- increased wheel mass of 716 and 936
- increased growth state time
- lowered sowingMachine01 (better ground contact)
- improved frontloader tilt mechanism
- reduced acceleration of 614(fl)
- increased acceleration of 716
- increased default stiffness
- increased liter per qm for grass
- tuned lizard wheel props
- getting more bales for windrows than for cut long
- fixed brakeforce of fendt 936
- added SHIFT+Q, to detach rows of trailers
- added support to directly start a savegame
- added career start point to map (for better mod support)
- added toggle help text button F1 key
- added zoom feature to pda (key 9)
Stuff it...purchased! ~_~;
Patch is 36Mb
What recession?![]()
Did you go for the download?
Not a bad price that.
