- 4 May 2006
- Manchester
Was there a way of getting these on the first run through that I've missed?
A lot of the trophies at the start are inaccessible due to your lack of gadgets. As you progress through the story you can backtrack to get the ones you've missed if you like. No part of the game that has anything collectable in it is blocked off as you progress.
I'm stuck.![]()
You need to use your security bypass gadget on 2 panels in the west room in order to shut down 2 of the pumps. They should be straight ahead as you drop down into the room, one for each of the pistons.
