Can we have some pictures of the screen in action please![]()
Lol I will post some when I get home, be warned though, my desk is a mess.
That video with the bust up box? My box was pristine, I'm glad to say.
EDIT: There was a cable that came with it, DVI, VGA plus 1 more, I assumed it was a HDMI looked like a HDMI but was slightly different and wouldnt fit when I tried it. Some research, displayport cable? Anyone know what this is used for?
Yep, I'm really gutted about the pixel because otherwise I really like this screen and have every intention of sticking with the U2410.I'm very happy with mine, sounds like Mkay is too bar the pixel.
Well, there's some caveats. But the risk of exchanging a monitor via Dell/others is, once they have your money, many companies tend to send from a pool of repaired/previously rejected monitors which may have already been sent back for various issues (What d'you think would happen to this current monitor?! It's perfectly ok bar the stupid pixel). I've seen quite a few people on forums go through several attempts and head banging to end up with something ok. Often it's probably not these guys being awkward - the companies are simply sending from a second rate pool and it may take you several attempts to get something without crap backlighting, dead pixels, or other issues etc. EDIT You can tell Dell to send you a factory new unit if you have to exchange it, and they'll often agree to this depending on the circumstances.. So that's what to do in the unlikely event you have to call on the warranty..And its if even 1 pixel they will change it?
Better not to look for something which isn't there for youI should really check mine out properly for any stuck/dead pixels.
Another reason I'm kinda reluctant to go this route is because you don't get a calibrated unit back (at least, not with its report) if you exchange it.
It's commercial reality and Dell aren't any different from most others in this regard. I learned this the hard way over 10 years ago when Iiyama kept sending me monitors with problems. I wondered if I just had really bad luck until I realized their on-site swap out warranty actually meant they were just swapping other peoples problem monitors, that had been sent back, for yours. As long as the monitor's "within spec" they're doing nothing wrong technically.That's a slightly worrying thought, the fact that you could believe you're buying new, yet end up with someone else's reject.
Indeed. It's also because the units are factory calibrated and only include a report with the retail packaging. Unless Dell send you a brand new unopened monitor it's not going to include the factory report at the least. Of course, if you don't have a calibrated RGB mode you lose much of the point of the monitor over the alternatives, unless you own your own calibrator.That's also nasty. Why should you be penalized for taking advantage of Dell's quality guarantee? (I don't see why you wouldn't get a calibrated unit back, anyway? Unless, as you say, these units could have been messed with by someone else before you.)
2 buttons. Press the 2nd from bottom (above power button) then the top and you get this menu. You use the 2 buttons beside the arrows to navigate up and down.How easy is it to switch between profiles? I mean, if I wanted to use sRGB mode most of the time, but then switch to wide gamut for Photoshop use, is that simply/quickly done, or is it a PITA?
This is with sRGB mode enabled. As you can (maybeI have no experience with a wide gamut monitor....how would the desktop image compare to the photoshop image if the sRGB mode was being used?
Dell's so called "Premium Panel Guarantee" doesn't cover stuck pixels; only hot or dead pixels are covered.Very lucky the premium pixel guarantee means you'll have no bother getting it exchanged![]()
As has been discussed you will likely end up with a replacement that is a "refurbishment"![]()
Hopefully not, but would you take the chance of getting a replacement that has more problems than the the one you sent back?Surely with such a new monitor there won't be a large number of refurb models hanging around in their repair centres yet?
Now I think about it, this was a lost opportunity by Dell. They allow you to define 3 shortcut keys, but they can only shortcut to Preset Mode, Brightness/Contrast, Auto Adjust, PIP Mode, and Input source.Please tell me it's a one-touch-button to turn on/off gaming mode?
Well, if anyone's curious about Dell with regards dead pixels etc, I've hopefully come up with a decent compromise. I'll explain a lot more about this later if things go ok. If they don't then the panel will have to be returned to OC for a refund within the 7 working days under the DSR. If that happens then I will also probably purchase from a retailer who offers a pixel check service. Although that's mostly a gimmick, where companies make an extra £20 etc, right now I'd have paid it to avoid the current hassle
This current panel is pretty much flawless bar this one pixel btw. I'm entirely confident many people wouldn't notice it, unless you use a white background often for word processing etc, or tend to be the type easily distracted by a tiny pixel
I'll keep you all informed anyway![]()
