Have read some but not all reviews but thoughts are that if you were building a new system then the i5 is not a bad choice but.....
I had decided that the extra performance that I might get from i7 was not worth the cost of the upgrade from theQ9650 am currently running @4.05
I'm afraid that I have the same view of an upgrade to i5 & as previously decided will hang on & see what the move to 32nm brings.
If I were building to a budget from scratch I'd probably go with i5 but might be tempted to switch to Amd as there appears to be very little difference in performance & for me it would depend on the actual deal I could make on the day.
This is using the CWC H50 though.
