OCCT on stock cooler, stock settings.
	75c on full load on stock is cutting it a bit fineBecause it's more than adequate for stock usage.
Nope just swapped the board over and it went in fine. Once it got to desktop, after a few mins it said I needed to reboot (the graphics were low res) and after that it was spot on.So did you not bother doing a full re-install? Everything work OK? I'm also coming from P35, and don't want to do a full re-install now, and then again in a month when Win 7 retail comes through my letterbox. Is it an OK thing to do for a month or so?
Did you have to un-install any drivers or anything, or just put the hardware in and stick the motherboard's disk in afterwards to install its drivers?
