Robot that can jump 7.5m
Minor problem with the OP robot. The piston will only be reliable on a flat, hard surface. Place on soft ground, or if the ground is on an angle!
So it'd be useless on sand, say, like in a desert environment? :p
Face it, it will be a complete and utter failure. It will simply be launching itself in a random direction.
I'm actually very impressed.
Each year it does seem that scientists or robot makers seem to make strides with robot functionality.
It may seem an ungraceful landing and not that impressive to some, but this could be an important step into how robots move around and whatever.
I look forward to more things developing.
Was expecting a bipedal robot. With lasers. And gatling guns.
Current robot has potential. Needs more explosions. and the ability to identify an angled plywood base.
Not unless you want to then go inside a building.
Just one thing I learn recently - the UK still maintains that a human operator must fire a robot mounted weapon (gun/missile) after evaluating the situation. The US on the other hand doesn't.
There's lots of interesting things in the pipeline. Israel's recon snake is interesting and spooky too.
there are other robots that can go inside a building.
ever saw those dragon fly things for kids that hover a few feet of the ground? wouldnt be hard to adapt the principals behind one for military use ;)
Yup. I'm currently working with a company in the states on stereo vision. The goal is an autonomous platform.
There are versions for air and ground at the moment with a ruggedised version with GPS navigation (the navigation board has just started shipping).
For stealth, a blimp works better - so you can fly a small blimp into a room a position it in the corner. It then doesn't have to expend much energy or make much noise to monitor.
What company are you working for may I ask?
The problem with blimps is their payload and size. Our lab pioneered some early control work using optic-flow on blimps but the platform was soon ditched for microsized planes and helis. To get even 20g of payload the blimp wouldn't fit through a doorway, you can forget about stereo vision on a blimp...
More of a pet project rather than working in a strict sense. The company is called Surveyor Corp. It's been targeting universities as a research tool but is expanding out into the small rover business through partners.
Your right, a blimp would be larger than a powered vehicle and there's nothing stopping a heli vehicle from using Gecko foot technology to stick itself to walls to reduce the noise and power requirements when in position.
