Sort of.
I've recently got one of these - Corsair H50. Which i've managed to fit where the 120mm fan goes, and it seems to work ok:O
The only modding I had to do was drill the 120mm holes about 10mm lower, allowing me to screw the rad in without it interfering with the HDD caddy. (tho it's mounted sideways and I only have a 2.5" HDD, I think if you had a 3.5 HDD in you'd have more trouble).
The reason i'm posting is to show off slightly (this is my first attempt at watercooling) and to ask a couple of questions. Should the pump be totally silent? As I do have a slight mechanical 'clicking' sound. And is the rad okay on it's side?
Thanks
Thanks
