Diesel Tuning - Ignition Advance.....
8 Mar 2006
Near Winchester
1. Advancing the ignition does not give you more power unless you are doing it to use a higher octane fuel in a petrol car.
2. Diesels until recently use auto ignition, which cannot be re-timed. Some of the high pressure injection engines inject the fuel at the point of firing/s, this could be altered, but there would be no advantage to pre-ignition.
OP
11 Jun 2004
Middlesex, London
Cool
But squirting the injectors that little bit earlier - Would that give you more power?
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
How? and what car?
In Diesels - The fuel is what gives power - So if you chuck in more, it will give you more power.
rover L-series, it's quite an easy engine to tune. Stock 100bhp can be taken to 155bhp/250ftlb for about £500.
The engine can only burn so much fuel, if I boot it, I will get some black smoke aka unburnt fuel.
14 Jul 2005
Bristol
No...as Rover416i found out when he 'tuned' his diesel Rover, it belched black smoke and gained about 5bhp...he'd also cranked up his turbo...and then blew a turbo hose ~30mins later.
Fuel is what gives all car their power. :/
18 Oct 2002
Castle Anthrax
The key difference is that if you overfuel a diesel it'll have crap fuel ecomony and spew black smoke out of the back but it'll still make good power. If you overfuel a petrol you will produce less power than if you fuel it properly. On this basis tuning a diesel for power is all about improving airflow then just chuck in 'plenty' of fuel.
24 Apr 2007
Southport
30bhp for £50 actually! :cool:
Boost increased to 20psi and TU1 tuning box - adjusts the fuel quantity. Shifted well for an old derv!
18 Oct 2002
Devon
All diesels have the equivalent of ignition timing (even the old mechanically injected engines), it's called injection timing. And just like a petrol randomly advancing the timing is likely to reduce power and eventually cause damage. The cylinder pressures are so much higher in a diesel that timing is even more critical than a petrol.
Many people mistakenly believe that the object of ignition timing is to get as much advance as possible, this simply isn't the case. Ignition advance is necessary evil due to the finite speed at which the fuel burns; the objective is to get highest cylinder pressures throughout the power stroke (hence highest torque and greatest power output). Do do this the peak cylinder pressure needs to be acehieved at a point somewhere past TDC (~15 degrees), and the ignition is timed to achieve this. More advance than this will not achieve more power.
The only time more advance will give more power is when the engine is running artificially retarded to start with, either to suppress detonation or because a higher octane (slower burning) fuel has been used.
