do diesel have VVT?
on most modern petrol cars you can adjust (independantly)
IGN Timing
VVT
Cams (switchoverpoint)
Cam switching is a form of Variable Valve Timing.
do diesel have VVT?
IGN Timing
VVT
And air, n'est pas?
sadly you can even bypass the egr anymore as its measured by the maf which will very quiclkly throw you into run home mode.
Which engines measure the EGR by MAF? Mine's blanked and it works a charm - a lot smoother lower down, only downside is it takes a bit longer to warm up on a cold day
mainly newer stuff 01 on depends on what each manufacturer desired, new cars with the tighter euro rules are forced to run with maf monitoring of the egr to stop naughty boys like you and me.
Or buy a petrol if you want to go quickly
Same with a diesel, still needs air mixed in, my point was 'In Diesels - The fuel is what gives power' also applies to petrol engines.
Cool
But squirting the injectors that little bit earlier - Would that give you more power?
Wrong again
less fuel gives more power on a petrol engine as the mixture burns hotter.
If I have a turbo car running at lambda 0.74 I can make more power by taking away some fuel, usually up to about 0.82 at which point making it leaner will cause excessive heat and lead to melted things
