Diesel Tuning - Ignition Advance.....
The original post I made was in reply Invader regarding making more power out of a given engine by adding more fuel.
It is correct for diesels, it is incorrect for petrol engines.
You can't really make a black and white statement like that without more details. A petrol engine running lean, or even at stoich will almosr certainly make more power by adding fuel. Likewise, if a diesel is already injecting enough fuel to producing lots of black smoke, then adding even more fuel just means you get even more black smoke.
OK I'll re word it..
A standard diesel engine, running at manufactures set fuelling levels under full power..
Add more fuel and it will make more power.
A standard petrol engine, running at manufactures set fuelling levels under full power...
take away some fuel and it will make more power.
It is that simple (mostly :D )
