[TW]Fox;14915034 said:Whats the roof rack for?
well this one is removable but i choose not to remove it
[TW]Fox;14915052 said:Do you carry a lot of stuff? I thought they were removable for when not in use?
[TW]Fox;14915090 said:Do you not think I was perhaps asking why you'd chosen not to?
Let me spell it out for you.
Is the roof rack part of your ridiculous attempt at styling?
sorry, i beg your pardon, the earlier GT's... did they run the non RR version which were 140ish, from what i can see in the haynes book of lies, they did as they mention about the ph1 2 and 3 engines, different throttle body housings etc is all i can see, the roller rocker version produces 150bhp yes.
the 140bhp sr20's have a precat in the downpipe and a cat along the underside which is why the boys on AOC can only assume of the lower bhp
not quite sure how they did it seeing as the RR version is the same in all late ph1 and all the ph2 almera gti's
.[TW]Fox;14915121 said:Because I quite clearly asked you what it was for, I'm not stupid, I know what a roof rack is used for, it was obvious i was asking why its left on the car.
Well obvious to most, perhaps not to you it seems
So, lets try again.
Why do you leave the roof rack on the car, is it part of the styling?
Not my cup of tea but i can appreciate the amount of work you've put into it.
Do you get pulled over by the Police often in a car looking like that btw ?
Good job he didn't look too closely at your platesjust for spot checks and to be told that im driving too fast.... apparently 25 in a 30 is too fast... think he wanted to check the car over
(I was just scanning through the thread, not really reading everything) ...I have never heard of this rat-look before. I thought for some reason you just hadn't gotten around to priming the bonnet at that stage, then ...then I realise that the mat black paint isn't actually some sort of base coat ...it's actually how you wanted to paint it. I am confused as to why?
