Ummm.... too much effort for 5ghz o.0
It's a good question fizzle-187 and one that could be debated!So would this board be beneficial for my i7 860?
My off the cuff remark would normally have been that this board is probably OTT for a beginner/nOOby overclocker as they are unlikey to tap the full potential, so in essence they would pay a large premium for nothing . . . well apart from loving the look of the board and braggin rights of course!
Having said that I think that the ROG series of boards do contain some nOOb friendly overclocking features like CPU Level Up, Mem Level Up etc. These added options are aimed pretty much at the beginner and make the task of getting more speed from your kit easier.
Personally I wouldn't recommend this board to someone who is doesn't know how to overclock unless they were rolling in money £££, instead you could choose from several more keenly priced boards and save yourself £50-£70 and start doing your homework and learn how to overclock!
The most important thing in overclocking IMHO is Knowledge, Patience and having the right kit to do the job properly (in that order heh!)5.0 Ghzzz ...... BLIMEY....I'm wondering if this is worth getting with a i7 860? I will be overclocking but it will be my first time. Any set pre-clocks in bios?
Test System
Intel Core i7 LGA-1156 870 CPU Stock Air cooled.
4GB Corsair CMGS2GX3M1A2200C8 ES1 Cas 8 memory running at 2200MHz
ASUS maximus III Formula
ASUS MATRIX GTX285/HTDI/1GD3/A
Samsung HD322HJ
Enermax 1000W PSU
Windows 7 32-bit stock install with no tweaks.
Maximum CPU 4584MHz using Intel's Stock Air cooled heatsink
QUOTE]
4.5 MHz on stock HSF?What sort of temps are you getting on this set up?
Test System
Samsung HD322HJ
Enermax 1000W PSU
QUOTE]
As there was no load on the CPU at this speed temps were low around the 47c, things did start to get a bit warm though when fully loading this CPU with the Intel stock heatsink around 4000MHz.
sacha35 i noticed you have done the oc on the Maximus III formula does this mean now there is a bios update that works with the oc station now on this board?
ah great was waiting for thisthanks for the info
hi,you not have a problem with the mb as it has a oc button,all you have to do is push that and you should geta auto stable oc of 3.6ghz.
