Well if you cant back it up with proof theres no point posting it.
I heard the worlds gonna end in 2012.![]()
I hear that too,it is when nvidia monolithic gpu takes over the world
Still getting blasted by the 295, looks like when the 300 comes out the glory will be NVidias once again.
The new cards are impressive, but not quite as dominating as I had expected from the specs. The fact that, at the highest settings, the 5870 loses out to the 4870x2 about as often as it wins is a little surprising, given the higher pixel throughput (of about 20%) and the lack of inter-GPU communication. I guess it goes to show the importance of memory bandwidth at the highest resolutions with AA (where the x2 still has the advantage).
I here you and I have done it myself but should we have to... No. Running a GTX 260 at the moment and this card is pretty much silent under load. While I appreciate it's a high end card I just wish they would spend some of the R&D money on cooling.
I would put that down to drivers.
Entirely possible. I guess that only time will tell.
Edit - I'm also ll for the idea of introducing massive "four-slot" coolers that can run virtually silently, in addition to the more noisy two-slot editions for SLI / x-fire. I don't think it's unreasonable for them to charge a $20-$30 premium for such a model, and I think there would be plenty of takers.
Edit - I'm also all for the idea of introducing massive "four-slot" coolers that can run virtually silently, in addition to the more noisy two-slot editions for SLI / x-fire. I don't think it's unreasonable for them to charge a $20-$30 premium for such a model, and I think there would be plenty of takers.
