Yeah, very good chance of killing the card with static.
Cut off the offending part of the cooler.
I don't have the tools to do that, and I wouldn't really know how to do it properly.
You need to saw the card just before the capacitors, then attach the cooler and glue the other end back on.
Should work fine![]()
Its very simple to do. Line up and use a marker to highlight what part of the cooler will make contact with the card.
Grab you self a junior hack saw or some kind of rotary cutting tool to remove the excess. Its only thin copper plate so it very easy to cut.
Err, I don't think so!It's metal for a start, not card, and I wouldn't be able to reattach the other end since it wouldn't fit in front of the caps, and there's also the 2 plastic vertical pillars to consider. or did I misunderstand you? Frankly, it was £15 and I might just buy something else that will hopefully fit as advertised.
Joke failI meant your GPU.
*finds door*
Id strongly recomend against hacksawing anything, but maybe thats just me being overly cautious
If you read the info supplied with the vortexx and any other aftermarket cooler they do specifically state that they will only fit reference design PCBs and to double check with your cards manufacturer whether your is reference or not.
Sorry, that's complete ********. There is nothing in the spec on ocuk, nor on the box, nor in the manual that says that. And there's no reason I should have checked with their website first bearing in mind the box says it's compatible with the 4870.
then again, it doesnt say 100% compatibility either. just playing devil's advocate. I wouldnt expect any cooler to fit my gpu unless i knew it was a reference design.
Where does it say that?? On the box and the manual it says compatiblity list, ati and nividia, then goes on to list all the cards including 4870. Nothing about reference or non reference. That's why I bought it. I'm happy I bought it because I'll get it to fit, but please stop making me feel like an idiot, because I've gone on all the information that was supplied before purchase.
We do our best to make sure the compatibility list is up to date. Our VGA coolers are designed to be compatible with all the ATI & NVIDIA reference design VGA cards we list, however occasionally some manufactures deviate from the reference design and therefore we cannot guarantee compatibility with these cards. If you not sure please contact us for help.
