^ Need for Speed Shift ^
Sneaky wins are WIN!
naughty ... i dont see the point of doing that tbh :eek:
bought a new gfx card so i got a new car for it, lancer evo :)
what gfx card did you upgrade to ? ive put my GTX280 in the hood now, it gets about 40-60 with a full grid on a stock 2.66Ghz c2d..
so when are we going to have a small OcUK online crash session, i mean race session ? sunday ?
does this game support SLI ? looked everywere, also get the g25 wheel much better you can use gears mind you it makes the game more work for you, try automatic from the menu.
PS have 2 gtx280 on sli gpuz said they are also nividia panel has them enabled.
Just had a wierd problem on a tier 3 race under manufacture race on the corvette c06. just wouldnt engage a gear, even using the keyboard. The trottle would redline then drop to 0 then redline, etc etc
Very odd, anyone got the same thing?
JT
PS add me on EA nation for clean race fun: Tagganator
*pic*
Nice driving mate. :)
Anyone have a bug where loading a race, it takes a little bit longer and them for some reason the sky is black? I've had it a couple of times, just reload the race and its good again.
went from a 8800gt to a bfg 260gtx oc 216 maxcore. can now run it at 1680x1050 with settings maxed 8xAS 4xAA and get 60-100fps on empty track and 40-80fps with 10 cars. big difference, more so at the higher res :)
cheers :) it's a little scruffy in places so time to be found.
Im playing the demo. Can you clear up the god awfull turn in understeer that happens at any speed in any car in the control setting some how? Ive fiddled with the settings, dropped the dead zones right down, lowered the sensitivity and turned off aids, but i still get masses of tyre squeel when turning in, or just no turn in and straight on, regardless of how much stick movement I use (360 pad)?
