Always liked that colour combo
Probably because all the 3's he's seen are ones that turds bringing after a good old rag and all the arches littered with stone chips and need for speed drifting (VTEC YO!) hence rust.
The 5's often being bought and driven by more sensible people (occasional hedge meeting excluding)
saloon i assume?
If so, ill start it
My facelift e46 330i Sport:
Why does your center console looked warped to the right? Unless its meant to be that way. Looks a bit odd.
the centre console faces the driver.
on LHD models, it's mirrored
don't quote me on this, but i think the sharkfin was introduced on the E65?
i also think it's for the phone and/or satnav, as the radio antenna is in the rear screen
and seeing as this particular example has neither gps nor an integrated phone, i'm going to go for aftermarket tat![]()
Going to quote you sorry
The shark-fin is standard fit on that particular 330Ci as it has integrated bluetooth.
By the centre console, you can make out the BT pairing button and also it has the snap in adapter mount rather than the roller-shutter.
