can i enter with Akuma and Blanka?
Yeah sure mate, but first please try and complete your games from league 1. But if ppl cannot connect to you, what can we do?
For me i have to turn res down to keep my fps decent while recording.![]()
Edit: Sorry, missed that bitEdit, its because I don't have the full version of Fraps.![]()
OK, I've added everyone (except naan and sem) but I've got a strange problem with Fraps. It records fine, and doesn't seem to effect the fps, but it seems to stop recording on it's own for some reason and I only get about 30secs. I checked the Fraps FAQ and it says that it keeps recording until you press the record button again.
Adz, my 1st choice is C.Viper. Still thinking about my 2nd choice.
camstudio
xfire
wasnt hard to find
Hang on... There is only one person who cannot connect to me.. I did have some issues with Naan previously but it works now.
From reading through it seems only im unable to connect with you now. Have you sorted out your NAT and UPnP problems. Ive read that a strick NAT setting can cause issues, also you need UPnP working really
That's fine mate but it was definately more then 1 person who had trouble connecting with you, luckily in most cases the problem was sorted.Hopefully this time round there will be no issues, BUT if it so happens that you can't connect with someone after trying numerous times I will have to appoint a win and points to the other person otherwise they will be penalised unfairly. Hopefully though like I said, it won't come to this. I can't think of any other way around it, is that ok with you?
If so confirm your characters and you are in!![]()
I rang O2 and they said they cannot change the NAT from Strict to Open. I am going to borrow a Netgear DG834 and that should hopefully solve it.
It is only you I have issues with now..
