Software: Controlling PC in a Training Room?
21 Jan 2003
Surrey
Hi All,
The last time I looked into this area, it was all hardware based. But things must have moved on :)
I have an IT training suite with 20 workstations. I want a software solution, so that I can take control of the PC's and show whats on my screen.
It would also be good to take control on the users, PC when they don't understand something and take them through it.
What the current software solution for this.????? Easy of setup and use is always a good selling point.
Any advice would be greatly appreciated :)
Pho
Pho
18 Oct 2002
Derbyshire
It's unfortunate the teamviewer website makes it look like some awful commercial software, when infact it's actually rather good.
OP
21 Jan 2003
Surrey
I have worked out how to install the software on a host machine and set up a group. But unclear on how to connect to the other 18 PC's?
It looks like you have to add each machines ID each time. This might be a problem as 5-10 year old will be using them :(
Is there an easy way?
or is VNC easier?
Pho
Pho
18 Oct 2002
Derbyshire
In teamviewer you can add (like I have in the partner list there) all the different IDs and then use quick connect. The IDs are unique to each PC and don't change.
OP
21 Jan 2003
Surrey
So if I run the scaled down client software on each PC, the ID will never change and I can just create a group and add each ID then?
an you quick connect a group or do I have to do each ID separately?
Thanks again
Pho
Pho
18 Oct 2002
Derbyshire
I think so, I've not really tried with the scaled down version though but it should remain the same.. try rebooting a couple of times and see.
You have to quick connect to each ID separately. I think. Teamviewer does give you the option to reverse the connection (again, not sure about with the scaled down version) so other people can see your screen though.
Sounds like you might need something else though.
OP
21 Jan 2003
Surrey
Lanschool
we have starting using this in the school i work at and its fantastic
http://www.lanschool.com/
simple to install
can monitor all the pcs in a room
control them
limit apps
limit net access
disable usb ports
and much more
There is a free version but i am not sure what has been disabled in it.
What sort of price is the school paying for that??/
I just been referred to
http://www.netop.com/products/education/school.htm
I'll try both when back on-site next week.
Thanks all
18 Oct 2005
Swansea
i don't remember of the top of my head
2k maybe for a site licence.
but you can buy licences for individual classrooms not sure on the price tho sorry.
never tried net op.
if you search for classroom management software you will find quite a bit of software that will fit your needs.
Don
21 Oct 2002
Parts Unknown
in this case, I reckon vnc might be the best for it..
install tightvnc server on all the client pc's
download realvnc on your machine, and use the client for that comes with that (best combo I've used)
OP
21 Jan 2003
Surrey
Can I get each client to connect automatically or get the main machine to connect to all the clients automatically
In one go?
If these clients are set up via the local admin account, will they work for each user account that signs into the clients PC?
Thanks for all the tips and guidance.
Svan
Don
21 Oct 2002
Parts Unknown
tightvnc can be installed as a service
so on your pc, you just open the viewer, type in the 'computername' and the password set for that computer (might as well keep them all the same) and you'll have remote control -the user can interact too
because it's a service, it'll work from the logon screen, doesn't need a user logged in
7 Jan 2005
London
Ultravnc will do the same. I've not used the versions past 1.2 though as I didn't have the time/inclination to figure out what is wrong with the later versions.
27 Feb 2003
Shropshire
NetSupport School is designed for that sort of task.
REAL TIME INSTRUCTION (SHOW MODE)
* Show the Tutor's screen to selected Students.
* Show a specific desktop to selected Students.
* Show just a selected application to selected Students.
VIEW STUDENT SCREENS IN REAL-TIME (MONITOR MODE)
* Monitor the entire class in a single view.
CLASSROOM MANAGEMENT
* Power On or Off all classroom computers from the Teacher PC.
* Perform a Remote "Log off" on all PCs.
* Send a Remote "Log in" to all Student PCs at the beginning of class.
* Blank Student Screens to gain attention.
* Lock the Student's Mouse and Keyboard when instructing.
* Automatically re-connect to Students PCs on Reboot.
9 Nov 2004
Pembrokeshire
Just been toying around with that, and the free version of that is brilliant.
I think we may start using that inside the company for tech support.
Do you know if it works cross platform? I.e. can the windows viewer see a Mac machine?
