Noooo! They had that in the original and then in Arma 1 but thankfully in Arma 2 it was removed. You can't run whilst reloading which is fair enough, but having you completely stop is stupid! What happens if you start to reload and someone comes round the corner, are you able to stop reloading or do you have to wait for it to finish?
Nope, it looks like this, runs well, seems to use all four cores on this Q6600. Just getting into it at the moment, there are a few things that are annoying, such as the slow weapon/equipment change and the inability to move when changing them using the scroll wheel. But this stuff can be fixed in patches I suppose. I have yet to try it online, there are a few servers up, but pings are quite high.
... war games have to be mass online mayhem !it is bound to have a few bugs and I think the dedicated server issue was a bit of a mistake but I have full confidence in this title and that issue being resolved.
Yup I've hit that one, mouse pointer completely disappears from menus etc too - you have to come all the way out of the game and reload it to get it back.enjoying it so far, only on the first mission as i'm doing all the secondary missions as well. However I've encountered a bug which a few others have mentioned on the official forums. If you try to select the different types of ammo using the ' key it renders the mouse wheel useless, and you cant select weapons![]()
The FOV is terrible and this is the first time that a game has made me nauseas. The textures are bad when you get close-up - especially trees and rocks.
Also I bound "use" to NUM ENTER, and whilst it works it doesn't close properly - e.g. if I press it on a dead body or ammo crates to pick up stuff, I can't close the item list box by pressing NUM ENTER again. Only way I managed to fix it was binding a secondary key to it.
From the short time I played they were not too bad. I am going to hold off in hope that there is FOV fix.what's the friendly AI like?
Aside from the respawn rambo syndrome.
Do you seriously believe Arma 2 will be massively improved by any subsequent patches?
The game has been out months now, nothing significant is going to happen. Its just the way the game is.
Game studios are damned if they do use amazing gfx that our rigs struggle with, and damned if they don't.
People seem to get outraged whatever the outcome.
The level of anger in this thread is fascinating.
Yeh FOV is bad and the screenshots that we have been seeing must have been through touch up, because I am maxing out every setting possible at 1680 x 1050 at roughly 100fps and it could look a lot better to be honest.
If you want a solid framerate and fluid action, I suppose it's not too demanding for lower spec PC's, but to be honest everyone on here is pretty much wanting/should be expecting lots of eye candy with the rigs that we run![]()
