Terrible speeds on Entanet
Thanks, is there any way to change the node you are on - ie does it select each time you login in or is it the same?
You only connect to one node.
It is not like the old way where you could try to reconnect to a less busy central.
I just signed up for a new account at ADSL24 and activated today. My connection speed is terrible. :(
Does anyone know what is going on? I have sent a ticket but no reply yet.
what are you sync speeds/connections stats? Also use this speedtester instead.
http://speedtester.bt.com/
Is this what you mean?
Nah, not the case, 10 days is at the outside. mine was a bit rubbish for the first couple of hours then it settled down. If its not sorted by tonight, reboot router/modem and re-connect - worked for me.
Nice upload speed though!
You wont get any more down speed based on those line stats.
They said there was no fault on the line. I guess I am just going to have to wait and see what happens.
I've had to wait 5 and a half weeks to get broadband activated and now this. :(
This the first time you've had broadband?
Disconnect any extensions, they could be causing problems.
No, its a new (6 month old) house. Apparently the previous tenant had Sky Broadband on the line but never used it.
There are no other extensions used.
I would expect between 2 and 4mbit at that distance, go find your main socket, take the 2 small screws out the front and plug the router into the test socket behind.
take the front faceplate off the master socket, plug your filter/router into the socket behind that and show us the line stats.
